I need to locate an "always hot" power source for my new XM. Everything else is a piece of cake, but the unit came with about three feet of wire with an inline fuse, built in to the main XM harness. Instructions say to connect this lead "to a terminal that is always supplied with power regardless of key position". Anyone know of a hot wire within three feet of the Head Unit that qualifies? Thanks in advance!
Wiring
Hot wire is pretty much only used for home wiring.
In a car its constant 12v
I know you already found the wire, but just incase anyone else needs the wires here are the EIA standard wire color code and the xB's wiring colors.
EIA Standard
Battery Yellow (+)
Accesory Red (+)
Ground Black (-)
Illumination Orange (+)
Power Antenna Blue (+)
Amp Turn-On Blue/White (+)
LF Speaker (+) White
LF Speaker (-) White/Black
RF Speaker (+) Grey
RF Speaker (-) Grey/Black
LR Speaker (+) Green
LR Speaker (-) Green/Black
RR Speaker (+) Purple
RR Speaker (-) Purple/Black
xB Wires
Battery LIGHT GREEN (+) RADIO HARNESS
Accesory GRAY (+) RADIO HARNESS
Ground BROWN (-) RADIO HARNESS
Illumination GREEN (+) AT RADIO HARNESS
Power Antenna ORANGE (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) VIOLET
RF Speaker (+) LIGHT GREEN
RF Speaker (-) BLUE
LR Speaker (+) BLACK
LR Speaker (-) YELLOW
RR Speaker (+) RED
RR Speaker (-) WHITE
