1 - 3 of 3 Posts
The problem you will run into with body kits is most of them require a body shops help. Most kits do not fit perfectly so you'll be able to install it but there are going to be parts that do not line up or fit the way it would if a shop installed it. The only kit I know of that has a near perfect fit is the 5Axis kit and even that one you can run into problems with if not done absolutely perfect.
1 - 3 of 3 Posts
