1 - 4 of 4 Posts
I have those same units. They mount just like stock, although you will need to drill a hole for the wiring, which is covered up by the lights when installed. You just tap into the blinker and stop lights with some wire taps. Make sure the taps are 100 percent secure or the lights won't work. I've gotten many complements on mine. ^_^
I got them. No need to drill any extra holes, bumper has a hole already.. I ran the wires through the body through a rubber grommet right under where the tail light is and its already there from the factory... You'll have to run a diode on the white wire or you'll have dash, front, and all other kind of lighting problems...
My first set I had one fail already and only had them 3 months... Would be nice if there were better ones out there than these cheap Chinese ones...
1 - 4 of 4 Posts
