Since my rear caliper is sticking some, I guess it's time to do the front/rear brakes. My question is, when doing the rears, do you have to take off the emergency cable from the caliper or can you just remove the caliper with the cable attached and get the job done?
If there is enough play in the cable to remove the caliper without removing the parking brake cable, that would be a bonus for me.
Update... It's easier to back off the parking brake cable nut (located inside the console by parking brake handle) and just remove it from the caliper housing rather than trying to yank and pull the caliper to clear the rotor. After you back off the adjusting nut by the brake handle, slide the parking brake cable end from the caliper, slide a 14mm box wrench over the cable end and pull the cable housing to release it. The wrench will compress the parking cable clip so the cable can just slide out of the mounting hole. My cable had a ton of corrosion from salt so I had to work it back and fourth some.
Thanks!
