You need to remove the bumper, or at least pop off the parts near the headlight and fender, remove the headlight. Once these are off you will see two bolts at the front edge behind where the bumper was, two on the inside edge of where the fender and hood go together, one under the trim at the base of the windshield between the wiper tray and the fender, one from inside the door jam up high, two down at the bottom of the door jam below the rocker panel, and finally one behind the wheel well liner facing toward the rear of the car. The liner is just held in with a single 10mm bolt and lots of clips. The is also a piece of plastic behind the liner that block water and dust from the getting to the door jam that needs to be removed, but it just clips in place and pulls right out.
