Toyota badge dimensions vary widely. If you want badges that are a match to the xB2, then the Rumion badges work, though the 2011 front badge may be dimensioned differently (don't know) -- if so, you'd probably need the nose badge from the Rukus. Check with Carson Toyota for compatible badges (though they may not have anything Rukus yet, would have to ask them about it):kmand83 said:I want to get rid of the scion logos on the front grill and on the hatch. Do all Toyota logos fit the holes that are there in the grill and hatch.
Any OEM part numbers will be great And rumion logos are great too!
The rumion badge is different. the pins are in different places and it isn't as big. I got it, and just shaved off the pins. It works, but if you look hard enough you can tell it doesn't fit.TrevorS said:Toyota badge dimensions vary widely. If you want badges that are a match to the xB2, then the Rumion badges work, though the 2011 front badge may be dimensioned differently (don't know) -- if so, you'd probably need the nose badge from the Rukus. Check with Carson Toyota for compatible badges (though they may not have anything Rukus yet, would have to ask them about it):kmand83 said:I want to get rid of the scion logos on the front grill and on the hatch. Do all Toyota logos fit the holes that are there in the grill and hatch.
http://www.newscionparts.com/index.php?id=135
Really? That's both disappointing and surprising -- I expected the rear hatch sheet metal to be identical to save factory cost. I saw a photo of the Rumion rear Toyota badge installed on an xB and it looked right to me (owner didn't mention having to mod it), way better than the nearest other identified competitor which was a Camry trunk badge.Chrevis said:The rumion badge is different. the pins are in different places and it isn't as big. I got it, and just shaved off the pins. It works, but if you look hard enough you can tell it doesn't fit.
