1 - 10 of 10 Posts
ok so i bought the spec-d halo/led headlights and they were fine but when i look again, one of the projectors is loose and is tilting down so the light output much less than the other one :(... what should i do? does anyone else have this problem? how do i fix it? -thanks-
dshiznit said:
i actually came across these same exact problems when i painted my headlights too. to fix the low light, theres a silver screw thing that you need to spin. it looks like a bolt but its not, it just keeps spinning so keep goin until the light is level.
I have the same problem, this is the answer I got ^ but I have yet to try it.
I don't. I don't even know if it's inside the headlight, or accessible without taking the headlight off. I'm hoping its the latter.
Nothing needs to be removed, the adjusting screw is very easily accessible from above. I had to adjust mine after installing my lowering springs, then again after installing my ANZO headlights. Very easy to do!
1 - 10 of 10 Posts
