OK, here's what I did to make 15" wheels fit on the back of my XB, which, by the way voided what remains of the warranty on my back brakes: I bought 2 new rear rotors and had a machine shop reduce thier radius by 3/8". I then marked and drilled new holes in the wheel hub and caliper mounting plates on the swing arm. The holes were drilled 3/8" inward toward the centerline of the hub and downward on the plate to prevent the new holes from overlapping the stock holes. I also fashioned two 1/2" steel spacer plates that I installed between the hub assembly and the swiing arm mounting plates to bring the rear wheels out to approx. the same width as the front wheels. I then had the spacers welded to the swing arm plates to prevent any possibility of the spacers slipping or shifting. I used the stock calipers, caliper brackets, and brake pads and everything works perfectly. Now, the reasons I did all that are these: I hate the look and ride of low profile tires and I wanted to see if I could do it. And I did! Also, according to Miata.net's tire size calculator, 215/70/15 tires are almost 2" larger in diameter than the stock 205/55/16 tires my XB came with and make my speedometer read 5mph slower than my real speed which is why I want to find a way to recalibrate it. Any ideas anybody?Later!Oldguy
