1 - 4 of 4 Posts
You need to install a line out converter. The line out converter is spliced to any speaker wires and has rca outs that can be run to you amp.
So you need:
Line out converter
Then continue the install like any normal sub & amp install. Power wire run to your battery, good ground, and a remote wire run to your fuse panel or an in-line switch.
Here is an example of the line out converter ( you can get a decent one for about $12, they all do the same thing):
http://www.ironpony.com/ironponydir...d/M2R/Class3/Full Face Helmets/Class2/Helmets
Do you know how I can get to those speaker wires without opening the doors or something? Cause I used a converter for my 07 civic but it was easy cause the speaker wires were just hanging around in the trunk. Also if I do have to go through the doors how am I gonna run the RCA cables back to the trunk?
1 - 4 of 4 Posts
