After reading the posts on removing the tail light ***'m's, everybody said to be carefull with the gasket on the back side of these lights,got me to thinking.Because the replacements from Scion are SO expensive($44+ each) why not use some roofing membrane.You know the stuff used by roofers when they put new shingles on the house. It does come in rolls,but they might have some left over from another job and will sell it to you or give it to you.Using the damaged gasket as a template,cut a new one. Got to be cheaper.
