Well I seen this come on yesterday so I filled the front two with air, no more warning, then today going to work it came on again? Im sure I don't have a leak, anything special I should do to make the warning go away?
Just check your pressure psi numbers on the door. My light came on the other day. and i filled my tires and it went off. If it still comes on after your tires are filled to the psi numbers. Then its the sensor. I had to replace one about 2 weeks after i bought my xb. Good luck.
the button is jsut past the lip of the knee panel on the right side of the steering column. just slide your hand down the right side until you feel the edge then about and inch below it a small button is down there.
Well it was a slow leak to begain with (D'oh!) hno: I woke up this mourning with a flat. I hope they can just plug it , of course road hazzard is not coverd in the tire Warranty. Thanks again.
Don't get it plugged... Go to an America's Tire Company and they'll patch it for free. I was told that if it's plugged, they can't touch it, but maybe that's just here...
