Gang, I wanted to give an update. I've created the PVC pipe capsule for my TPMS sensors........and it works!
I bought some wheels, and I took the TPMS sensors from the steelies and placed them all inside a 3" diameter piece of PVC and glued on two endcaps. Before gluing on the second endcap, I drilled a hole and placed a regular rubber valve stem in it. I even put some small pieces of foam inside to keep the sensors from rattling around. I sealed it all up and inflated it to 35 PSI. I placed the contraption in the trunk area underneath the trunk floor in the small well on the right side. The TPMS light on the dash went out within 1 minute. It hasn't returned in weeks.
Total cost about $10. Total time about 20 minutes.
DIsclaimer: DO not perform this trick, It will defeat the purpose of the TPMS system. I accept no responsibility if you try this
