Because Scion doesn't recommend a trailer,there isn't a hookup connector. You could go into the harness and tap onto the wires involved. I would suggest using LED trailer lites because they don't add much load to the existing circuits.
Both Curt and TowReady have "T" hookups available online, they plug into the tail light connections and as said, have a power wire to feed to the battery with a 10A fuse. I just installed a TowReady on mine, but I tapped power from the ignition switch instead of the battery.
