Does the TRD CAI really do anything? Does it have the ability to change the way the engine breathes like it says? Will it give the car more HP or torque?
I have the drop in and dont feel any difference, not even in sound. ill get the typhoon soon.Isn't the TRD Cai system more of a Sri then Cai like the k&n?
I want the k&n typhoon but can't get it now ($) so maybe I'll get the drop in k&n for now, I wonder if the filter swap actually makes a slight difference?
Thanks for the tip. I thought some claimed an mpg and even sound boost (both slightly) in some filter swaps. Guess it's better to save money toward a Sri instead. Thanks.I have the drop in and dont feel any difference, not even in sound. ill get the typhoon soon.
Thanks lots of info. I'm in NY if you don't mind me asking was it crazy expensive to have it done at the dealer?I haven't posted here yet, but now that I've had the TRD CAI in for longer, 1.5 months now (I had it installed right about the time this thread started), I can say I really like it. This is the newer TRD CAI, on my 2012. Especially with the different temps outside, my car seems faster, and there is definitely a new growl on acceleration. I think there's a little more jump on pedal press, and a little more giddyup in longer acceleration like on-ramps. It isn't big in both cases, but just noticeable. Plus, the thing looks **** good in there. For gas mileage, so far so good. I might be seeing a slight improvement.
@zinger - for the sound - it's not much louder actually so definitely don't be concerned about that. @NYxB - yes it's more like a short ram. It's basically a bigger pipe to the engine, a bigger airbox with a higher flow reusable filter, and then a bigger intake pipe that sticks down a bit and doesn't 'S'. It's kind of like a short ram on the end of an improved airbox. I like this design, though it's not as pure as a CAI that is a long pipe with a cone filter on the end.
Yes it's overly expensive compared to other ones, probably for the trouble they went to for the looks and it's Toyota of course. But the reason I got it, and had it installed by dealer was because of warranty, and this is the front-end of the engine. If you have warranty concerns, or emissions concerns, then you might want to consider paying more for the TRD CAI.
I took some pics of the CAI before install and after, so I think I'll put up a post about it later.
Awesome thanks. Aftermarket can't affect the factory warranty overall except the particular part changed I'm assuming. So getting a TRD will still be covered over not getting it I guess. Wonder if anyone actually knows who is the manufacturer of the TRD intake.Check out the TRD cai installation instruction here. It looks like a fairly simply diy. Even if you install it yourself, the parts are still under warranty from Toyota (and won't impact your xB's warrant).
Thanks! Well from the way it sounds, I think it would be pretty awesome with a new exhaust. It's funny you say that because I was paying attention to the sound yesterday after my post and thought that exact thing - wow that sounds good, and would probably rock with a different exhaust. It's still fairly quiet so could definitely stand to be a little louder, and I'm not even one to like loud stuff normally. I will try to listen for a air-sucking sound, which I haven't heard yet and I do hear in other CAIs. This design might not give the sucking sound, with the big inlet, air box, etc.Thanks lots of info. I'm in NY if you don't mind me asking was it crazy expensive to have it done at the dealer?
I like my Borla exhaust I wonder how the TRD Cai would be with it.
So it's not a cone type filter but a bigger higher flow type filter? The xB does sound nice with intakes let me know if you post a video.
Enjoy the new mod!
Good link. I have looked at that a bunch of times. It also came with my CAI and I left it in the box for the dealer to seeCheck out the TRD cai installation instruction here. It looks like a fairly simply diy. Even if you install it yourself, the parts are still under warranty from Toyota (and won't impact your xB's warrant).
However, according to the FTC, the manufacturer or dealer must be able to demonstrate that it was the improper belt replacement — rather than some other defect — that caused the damage to your engine.
