is it worth it? ready go!
Jon, it sounds like you are talking about swaybars (or as some call them, anti-sway bars) which bolt onto the suspension under the car in order to counteract body lean during cornering. They work by transfering suspension extension on the inside (unloaded) side of the car during cornering to the compressed suspension on the outside (loaded) side of the car via the torsional twisting of the bar.While it's not a transformational difference, the swaybars have improved the steering and of course body lean, and it seems to be more important than the shocks.
Are you telling me that my SR intake doesn't add the 50 HP i feel and hear???Placebo effect...
The tendency of any medication or treatment, even an inert or ineffective one, to exhibit results simply because the recipient believes that it will work.
AZ
That's what the "Sports" car is for!Are you telling me that my SR intake doesn't add the 50 HP i feel and hear???
I don't have any suspension modifications, yet but I plan on adding the Hotchkis Sport Suspension Sway Bar Package and some springs.
As for your question, from what I heard and read, the FST Bar is a good looking addition and might be useful of you drive hard on cornering.
A lot on whether something "works" or not depends on the specific vehicle design.Miatae have a very strongly mounted top to the shocks. So, there is little to move anyways. Therefore a Miatae strut bar does little.Placebo effect...
I also own an Miata, a NC model. I have tried many many upgraded shocks, springs, sway-bars! I also have oversized wheels & sticky tires on the 07 GT soft top. When the xB was purchased the Miata turned into my garage queen.:biggrin: At this time I'm having a fabricator install heat shields on a full stainless steel header then it's off to be ceramic coated, got to keep the heat inside the exhaust. The Miata has the full SS exhaust system, CAI and other aftermarket parts. After all the parts are bolted on, it will be time to get the car tuned on the dyno. $$$ :help:
So to get in *my* .02 cents in here. The front strut braces on late model auto's is nothing but underhood bling! The National Champion in the SCCA auto-x runs an NC model Miata with 18x9.5 wheels with 285 Hoosier race tires stuffed under the fenders. He runs aprox. 750 lbs front springs & 500 lbs rear springs. He removed the "Front Shock Tower Brace" on his trailer queen (race car) and when I was changing the susp. on my Miata I took the FSTB off to be powder coated. When it was off being powder coated I would take the car for test drives. I really couldn't tell one bit of difference with or without the FSTB!
Your auto, your money, do as you please! Just my .02 cents.
I have installed a TRD rear sway-bar and to look at the way it mounts I thought the same would be true about this sway-bar, Placebo! But I must admit I think it really helps remove the sway in the Scion body. I have also changed the tires & wheels, this helped more than the sway-bar. I have Eibach made TRD springs setting in the garage to be installed shortly. I would have changed the springs first but it's too hot in our garage in the AZ summers.
AZ
I was colloquially referring to both parts as "swaybars," but yes, I'm referring to the same TRD parts we're talking about--I have both the "front strut brace" and the "rear swaybar" installed.Jon, it sounds like you are talking about swaybars (or as some call them, anti-sway bars)...It's very different from a swaybar, which is mounted under the car.
My eBay strut tower brace (not TRD) barely clears the stock air intake plumbing. When I first installed it, some of the air intake plumbing was hitting the brace under idle and under certain load conditions. I fixed it by loosening hose clamps and twisting some hoses slightly to clear, then retightened the clamps. No more rattle. Not saying this is your problem, jsut sharing my experience...I put the front strut brace on and now I have a bad rattle.
