The answer is yes. I was strolling around in a local auto parts store (Salvos),and found a LED cargo light. It was flat,about 3"x5" with 6" leads,gray in color,~$20. To install it,measure to the center of the headliner,just behind the roof support,punch a small hole for the wires. The liner just pulls down a little,enough to run the wires.Pull the side panel to access the cargo lite/switch and hook up the lite to the switch, put all panels back. The lite itself,has double stick tape and 2 small screws.carefully put the screws in so the assembly snugs up.One more thing off the to do list.
