Worked all weekend on two boxes to fit 10 inch subs under my front seats. I used 3/4" mdf and it worked out to about 0.6 ft^ 3 for each box. I used 2 flat boss phantom subs which have 4" mounting depth and 0.6ft^3 sealed enclosure air space so it worked out nicely, plus each sub was only about 30$ so for a budget they work good. the boxes were sealed with silicone and then spray painted to protect the wood from water from peoples feet. I then carpeted them to try and match the floor carpet.
I moved the wires and brackets from the under seat computer such I saw someone else on the forum do. Under the drivers seat I moved the yaw sensor underneath the cup holders and got rid of the brackets.
I mounted the amp under the rear seat. I had to cut the hard plastic towards the back to fit the amp.
Surprisingly even with 10" subs there is still lots of room in the back seat.
Sorry about how dirty the car is but its hard to keep clean in the winter mess here.
The mats in the backseat just have dried salt from the roads, not mud
