UNICHIP is now available at Sparks Toyota/Scion for the 2005-2010 tC and 2008-2010 xB.
The Unichip is the universal performance chip and programmable computer that does engine management, custom tuning and engine control.
Easily plugs into the stock ECU & ECU harness in minutes , no programming necessary.
Realizes the full potential of Aftermarket add-on's like Cold-Air-Intakes & exhaust systems , as each kit comes pre-mapped for the exact set-up of each car or truck.
No end-user tuning necessary , just plug the kit into the car & you're ready to go.
Easily upgradeable for future add-on's.
Each kit comes with two maps : a low octane performance map & a high octane performance map, switchable from within the vehicle.
Fully tuneable by a Unichip Custom Tuner for customized add-on's . This basically means that the Engine Management System in your ride is now as tuner friendly as the most advanced Standalone systems in the world , without sacrificing any of the factory features. This feature is unmatched by any reflash-tuning or other similar product.
Plug 'n Play harnesses are fully Flux capable - purchase Flux when you purchase the Plug 'n Play kit or upgrade later - Flux simply plugs into the Unichip Plug 'n Play harness.
Plug 'n Play kits are removed from the vehicle in minutes, returning the vehicle to stock tuning , without leaving a footprint of ever having been modified (a feature which reflash-tuning cannot match).
Dynomometer Tests:
http://www.trdsparks.com/images/2620021Dyno-05SciontC.pdf
Check us out in the Engine Electrical section at www.trdsparks.com
So let's say I get the chip and then I install it. Then later I want to get a cai. Would I have to change anything?
