1 - 11 of 11 Posts
I decided to add a little style to the boring interior of my ride. I dont know if im gonna do the rest of the dash trim pieces cause this part alone was a pain in the a** lol. anyway, lemme know what you guys think.
Haha I was afraid of that! I was looking at the area with the heater/ac controls and I dunno if I have the skills to for the vinyl around them in a "clean" way.
Sorry guys i know i should have done a DIY but i did this after an epic FAIL of using vinyl on the front bumper and was so frustrated haha.
This is how i did it:
-Take dash piece off (i used a DIY from this site to do this)
-When the piece is out of the car, you still have to take the lower trim off as well as the vents.
-Now you will be left with the piece that you see coverd in vinyl
-Next i put the dash piece on a piece of vinyl to kind of mock it up. Cut a piece of vinyl that is about 2" longer on all sides of the dash piece.
-Now just peel the vinyl with the sticky side up, and just lay the piece on. I did this on the floor.
-Here is where you will need a heat gun, or in my case... my wifes hair dryer.
-Turn the piece over and begin to work on one side at a time. You will heat up the vinyl and start stretching it over the curves. This will get a bit tricky because you might get a few folds. The good news is that using the heat you can just lift the vinyl back off and fix it as many times as you need. Be careful not to heat and stretch it too much because it will eventually break.
-Repeat for the other side
-Now for the vent holes and the square spot for the radio, i heated the vinyl up, poked a hole thru it and cut 4 slits into each. (picture the cut as the N,S,E,W sign or a + sign) You have to make these + cuts in each vent hole and radio hole.
-Work on one section at a time, use a lot of heat and stretch the vinyl toward the inside or back of the dash piece.
-Once you are done you may or may not have to trim excess vinyl from the back
-If you see bubbles heat the area and try pulling the vinyl off, stretching it again and lay it smooth
-when you are satisfied put the trim piece back on and the vents as well. Be careful while putting the vents back in because you may mess up the vinyl that you stretched toward the inside.
Well i hope that was some sort of help, as much as it could be without pics. And if you think you cant do this.... trust me you deff CAN do it, cause i have no skills at vinyl work or window tinting or skills with a blade and it still came out pretty **** good. Took me about 30 mins tho but im sure you guys could do it quicker.
Thanks for the compliments guys!
Thanks, that sounds easy enough. I'm looking for something new to do.
No problem, if i end up doing the rest ill post pics this time. But i know you can deff do this. Post some pics up!
Ok got a lil DIY together...nothing too crazy but here it is with some pics.
Take the dash trim apart
Next take each piece of the trim and cut the vinyl around it leaving enough space all around to wrap the vinyl over
Now put the vinyl over the piece and apply some heat
Should look kind of like this...
The piece with the ac/heat controls is the hardest to work with because of the circles... your gonna have to do a lot of work here. I cut the circles out but they werent perfect so i ended up "filling in" the edges with strips that i cut to fit. Its not too noticable but i know its there and it kinda bothers me haha. anyway...
After heating and stretching and re-heating and stretching you should be left with this
Now you can put everything back together
Discussion Starter · #11 ·
Dont mind the mess!
1 - 11 of 11 Posts
