1 - 9 of 9 Posts
Eric said:
A full registry would most likely require a lot of programming and database work... I can see if there is a mod/hack to add more options to our profiles. Again, adding too many mods/hacks makes it harder to keep the forum script updated and secure. But, I will look into it.
Thanks for taking a look at it!
Eric said:
I found a good one, but when I ran the test, it failed. It looks like it may conflict w/ another mod, so I'd rather not use it w/out looking into it further. For now, you're probably better off creating a thread for updates of your xB & linking to it in your sig.
they have one on SL, but i do not know if it is compatible w/ your set-up...
There is one that is used by Jeep forum. The info you create is listed under profile for you to create. Then under you avatar there is the title of your vehical. Example "08 RS5" When someone moves there cursor over it down pop the basic description you put in. I don't know how it works but here is the link if you wanna check it out.
www.jeepforum.com. Just check out anyones profile info in a thread.
1 - 9 of 9 Posts
