1 - 6 of 6 Posts
Left a lot out here...
I assume you mean Intake. If so, what year tC? The newest has a different motor and since its release I think its had 3 different motors. That said, every motor has different fits (usually) so be aware. The easiest way is to do two things. First, see if the manufacturer's part number is the same. Second (if that wasn't the case) call Weapon-R and see if they jive.
A CAI will won't fit UNLESS it is very, very adjustable (to have the tubing route completely changed).
A ram MAY fit, but only if the only mounts are on the engine block itself.
The engine is the same, but pretty much everything around it is different. Our engine area is much taller and different shaped than a tC. As such, how stuff is situated under the hood is rather different.
1 - 6 of 6 Posts
