I was talking to Eviljack and the subject of wider tires came up.
From my over a decade dealing with small sports cars, I have learned that TIRE design/composition is what determines grip, not really width, unless you have a high power engine.
I thought it would be helpful to post some support for that idea:
From: https://lists.cs.wisc.edu/archive/vfr/1999-April/msg00052.shtml
Mike Guillory wrote:
> > From: Dave Aley <[email protected]>
> > Perhaps Mike Guillory could pipe in here and enlighten me as to how the
> > contact patch REALLY works. Am I completely off-base in my assertion
> > that a wider tire has a larger contact patch, Mike?
> *** I will, only reluctantly. I'm not an engineer - closer to a
> physicist/chemist/mathematician (retired)! If you *neglect* other forces,
> like tire wall rigidity, for a given weight rider+bike at a given tire
> pressure, upright and still, the contact patches (square inches) of
> different width tires *must* be the same. Physics gives it no other
> choice. The wider tire may have a wider contact patch but, if so, it will
> be shorter from front to back. However, there are other supporting forces,
> like sidewall rigidity, but for a 350 pound force (per wheel) I would think
> that to be pretty small.
I think there's an error in your assumptions here, Mike.
Strictly speaking, it's not the pressure inside the tire that supports
the bike. This pressure is completely constrined by the tire, so that
even when your tires are not in contact with the ground they contain 35
psi (or whatever you've inflated them to).
Furthermore, consider the area of the contact patch. Andrew said he got
a contact patch area of 2.4" for each tire; let's assume (lacking better
data) that the contact patch is round. (This assumption follows
logically from the assumption that the tire width does not have any
effect on the contact patch width; if that's the case, then the 11" or
so radius of the tire does not give you more length than the 7" or so
radius of the tire profile). The area of the contact patch is then 4.5
square inches. Now, Andrew on his bike probably puts a load of around
300 lbs on each tire; 300 lbs/4.5 sq. in = 67 psi inflation pressure to
get this width of contact patch. Since that's obviously more pressure
than Andrew is running in his tires, we have to throw out the assumption
that hydraulic theory can explain the width of the contact patch.
When you put the tire on the road and put 300 lbs of motorcycle and
rider on it, the pressure inside of each tire will rise somewhat.
However, it's not a dramatic rise, considering the small change in
volume. (Note that I'm talking cold pressures here, not the pressure
increase you get when you get the tire hot.) Therefore, we can assume
that it's neither the pressure (35 psi) nor the pressure rise (I'd
expect no more than a couple of PSI) that supports the weight of the
motorcycle. Rather, it's the rigidity of the tire that is imparted by
the fact that it's pressurized that supports the bike. This rigidity is
a function of the tire's elastic properties, construction, and probably
some other variables.
Now, this does not prove that a wide tire has a wider contact patch than
a narrow one. Nor does it prove the converse. However, I think it's an
important distinction to make.
> So, why do racers use larger (wider) tires? More total surface to absorb
> wear? Under hard acceleration, is the wider contact patch more important
> to give grip and prevent rear wheel break-away? Does a wider profile cause
> less of an upset of suspension geometry at high lean angles? Perhaps all
> of these, and more. But, for us mere mortal riders, I think we should,
> correctly, assume that the size of our tire's contact patch, under most
> conditions, is independent on the size or width of the tire. Any small
> differences will be greatly overshadowed by differences in air pressure we
> may choose. Go from 36psig to 24psig and increase your effective contact
> patch by about 50%!
So if I go from 36 psig to 1 psig I'll have a contact patch area! ;-)
One possible reason that racers use wider tires is heat. The heat is
generated by deformation of the tire; even assuming an equal contact
patch width, a narrow tire has to deform more than a wide tire. The
wide tire also has more mass to heat, and more surface area to dissipate
heat. This would help keep the wider tire cooler, allowing it to be run
at lower pressure and therefore increasing the width of the contact
patch.
Dave Aley | mailto:[email protected] DoD#454
Maintenance Mechanical Engineer | ASME #6363402 TLCA #8419
Lee Ranch Coal Company | http://www.cia-g.com/~aley/
Grants, New Mexico, USA | '87 VFR700FII '71 FJ40
The VF/VFR mailing list--see http://www.cs.wisc.edu/~john/vfr-list/
for subscribe/unsubscribe, policy and archive information.
> patch by about 50%!
patch.
