1 - 4 of 4 Posts
I've just noticed that the driver's side door's window weather seal is split and needs replacing. I've looked on line and have found the part. It is called a belt molding P/N 75720-12820. Sparks Scion lists it for $34.93. Now, has anyone replaced one of them and what is involved?
I just replaced these. They are clipped in towards the handle of the door and slid in slightly under the side view mirror. I just pulled them straight up and angled the old one out. Then carefully seated the new one. Very quick to do.
My window seal update: I did the replacement my self (of course) and it was a piece of cake (as they say). It took longer to get it out of the wrapping than to actually change it out. I have noticed that some are now seeing the same problem. If you go to the dealer, (not) the part will cost $50.00 plus $150 in labor. I got the "belt molding" from Sparks Scion for ~$40.00 and the install took several minutes.A flat blade screw driver and a paint scraper is all that is needed.
1 - 4 of 4 Posts
