1 - 8 of 8 Posts
Chimuka said:
Here is my idea.  Hope to have my XB lookin like this less the roof modification...http://i46.tinypic.com/2dtqioz.jpg
http://i46.tinypic.com/1zywvtl.jpg
Am I inserting the photos here correctly?
If you use the img codes, it would be this:
I like the look. As the rear C-pillar is shaped/structured the way it is, it should work GREAT!  You'll need a REALLY good body shop, plus add a panel in the middle (as lowered it will be slightly longer than stock).
I like the t-bird window. Does the c-pillar have to bar running through it? or could someone remove it completely and replace it (or most of it w/ a window? i might photoshop a mock-up later.
Very original though scion-ara, i like it.
There is a gap where the pocket is. They could have had a corner window, but went with a place built in for a speaker instead. The "c-pillar pocket" storage nets were provided for those that prefer the extra space to store stuff outta the way of the floor when seats are down.
To look, all one needs to do is to pull the upper piece away from the side (it just clips in there) and look.
1 - 8 of 8 Posts
