1 - 4 of 4 Posts
Hey all,
I'm looking at installing an Xm radio plug and play. Several ????? Where did you mount your receiver? What brand did you purchase? I have the factory pioneer T1808 radio that is SAT ready, but I need the fit kit. But after I found out how much it was going to cost at the dealer,not including installation ($850.00) I nearly shat myself and with the amount of work its going to take (Disassemble inside of the car), I decided to go portable. Thoughts??? Thanks!!
2008 xB
I bought the actual part that scion installs from www.trdsparks.com and did my install myself as per the scion install sheets (get from trd's site). The install was clean and neat. Unit went under the seat. Came with EVERYTHING you need up to the grommet to pass the wire from inside to outside via the taillight. If you're looking for a clean factory install that was the way to go...
Marc
1 - 4 of 4 Posts
