Manual Transmission Fluid experience/opinions
7.4K views 9 replies 6 participants last post by  CaptRMac
#1 ·
I'm going to change out my manual transmission fluid to a nice one, probably amsoil. But I wanted to see if anyone else had changed theirs out and had any experience or any luck with any particular brands or types. Thanks :smile:
#4 ·
Nice. That's what I'm looking for. Just want to smooth in up a bit. Was also going to install a set of the aftermarket shifter bushings as well. They made a big difference on my srt-4 so I'm assuming they would tighten up the shifter a bit on this as well.
#9 ·
i changed my trans fluid with 2 quarts of mobil 1 75w90 then 0.6 quart of synthetic lucas oil stabilizer
the lucas quite a bit with smoothness
i also recommend replacing the drain plug and washer and removing the reverse sensor (on top) to fill it and replace the washer for that as well
there is a tutorial on a tC forum somewhere
